falcon 150 mkII
Old Oct 16, 2005 | 09:25 PM
3boysmom's Avatar
Default falcon 150 mkII
can any one help me? We just got a few bike a few weeks ago and were adjusting things when we noticed on the engine it says 124 cm NOT 149 are all like this or did we get ripped off , want to know before i start cusing
Old Oct 16, 2005 | 10:28 PM
Raptoryfn660r's Avatar
RIP Dear Friend
2005 Falcon 150 150CC ATV Adult 4 Wheeler Quad
Ignition : 12V CDI with Keys
Engine : 149cc CVT, 4 Stroke, Air Cooled System
Transmission : Fully Automatic with Reverse
Start : Electric
Drive Train : 2 Wheel Drive Chain Driven
Suspension : Dual A-Arm full suspension, rear swing arm
Bore / Stroke : 57.4 x 57.8 mm
_______________________________________________
I am no expert on the quads but I went and looked at the advertised bore and stroke to see if it adds up to 149cc and it does so I am a little confused about what the 124 cM is doing on your engine.
Then I look at the Falcon 110 Baby
with these specs:
Engine : 107cc, 4 Stroke, Single Cylinder, Air Cooled
Transmission : 3 Speed with reverse gear, Chain Drive. Semi Automatic
Bore x Stroke : 52 x 42.5mm
Compression Ratio : 9.6:1
Ignition : C.D.I
and with this motor going by the b x s I come up with about 90cc.
I am not sure what the correct answer is here.
Old Oct 16, 2005 | 10:38 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I just went out and looked at my wifes Yamoto150 and it says 124cm3 down on the left side of the engine. I never noticed it before. Im not sure what it means, but at least it doesnt say 124cc.
Old Oct 16, 2005 | 10:39 PM
3boysmom's Avatar
my sons meerkat 50 says 49 my brothers falcon110 says 108 his 250 cougar says 249 so i am guessing i really have a 125. but i searched all over and i cant find a 125 advertised for kazuma. so anyone with a 150 if you could check what your engine says for me--- thanks
Old Oct 16, 2005 | 10:41 PM
RIP Dear Friend
I wonder if they are using the casting off another machine but why leave the 124 cm3
My honda 70 which I knew was actually 72cc say on the motor 72cm3
Old Oct 16, 2005 | 10:43 PM
KTM Patrol
Former Chinese POW!
On my wifes yamoto the numbers are a fresh cut kind of deal not old casting marks.
Old Oct 16, 2005 | 10:46 PM
3boysmom's Avatar
it does say 124cm3 on our 150. the book says it is supposed to be 149cc.and on the web site where we bought it from said it was a 149cc. any other way to tell?
Old Oct 16, 2005 | 10:52 PM
RIP Dear Friend
You would have to measure the bore and stroke of your motor to know for sure but the 124cm3 is telling us it has 124cc
I wonder if anyone has had one of these motors apart.
Old Oct 17, 2005 | 12:33 PM
3boysmom's Avatar
here is what i just found out about ourfalcon 150 mkII thanks for help everyone!
Hello,
Yes that is a Falcon 150, that number you are seeing is just the
volume of the crank case, which matches the 150's I have here. It is a
149cc, if you see that it actually says cm3 next to it, this is only the
volume of the crank case & not the actuall cc's of the motor, so you are
fine, the vin# also checks out to be a falcon 150 also. Hope that helps.
Thanks, Jim
www.kidatvs.com
Old Oct 17, 2005 | 09:29 PM
KTM Patrol
Former Chinese POW!
Thanks 3boysmom, I was just out in the garage looking at my wifes yamoto again. I was getting ready to pull off the head shroud and see what it said under there.
