1987 LT 80 problems
Old Feb 16, 2006 | 06:05 PM
Trunks's Avatar
Default 1987 LT 80 problems
I just got my hands on a 1987 LT 80. I have really have no experience with them. It runs great but does not want to move. I rev the motor and it will move a few inches. From what I know which is not much, I am thinking it is the clutch. Anyone have some tips on what I can check, or do I have to take it into the shop?[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Feb 16, 2006 | 09:44 PM
WeLuv2Ride's Avatar
Check the easy stuff first. Get the tires off the ground and see if they roll freely. If they don't, might have brakes locked up....or even the parking brake on? If they all roll freely, could be clutch or axle bearing, chain binding.
Old Feb 17, 2006 | 12:08 PM
LT80's Avatar
LT80 Expert
Ya, check it over, but clutch maint is needed I'm sure. [img]i/expressions/face-icon-small-smile.gif[/img]
I suspect you'll find the grease in the front clutch hard as a rock and causing problems. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 17, 2006 | 12:54 PM
maggiesboy's Avatar
"One Wheel Short"
as already stated, make sure the parking brake is off after you get it started. The front brake cables on these things are junk. You need to stay on top of the cable maintainence, or you will have "sticky" front end. Just my two cents.
Old Feb 17, 2006 | 01:23 PM
Trunks's Avatar
Thanks for all of the help and info, I will check it out and let you know how it goes.
Another question, I have been told if the peacock on these bike goes bad, it will contitue to push gas into the carb and then it runs bad and the carb leaks, anyone know if that is true. If it is, do you buy a new one from the dealer or is there a better answer to this problem.
Thanks
Old Feb 17, 2006 | 03:51 PM
maggiesboy's Avatar
"One Wheel Short"
Thanks
BANSHEE PETCOCK!
Old Feb 18, 2006 | 12:49 PM
Trunks's Avatar
Thanks for the info, Pulled the clutch apart and the rollers were done rollin, replaced them and it works great, will go and get a banshee petcock.
Thanks [img]i/expressions/face-icon-small-happy.gif[/img]
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
