Lt 80 carb problem need help.
Old Jun 1, 2007 | 08:49 PM
LT80's Avatar
LT80 Expert
Default Lt 80 carb problem need help.
Welcome to the forums valen. [img]i/expressions/face-icon-small-smile.gif[/img]
Fuel is weeping by the petcock and or there is something in the float needle seat, or both. [img]i/expressions/face-icon-small-smile.gif[/img]
Start with a good carb cleaning including removing both jets and the needle seat.
Old Nov 28, 2010 | 01:09 AM
rcastorena's Avatar
I have found that these carbs will always leak fuel/overflow fuel when fuel is supplied to them. This is why they used the vacuum operated pet **** from the factory. Once this starts to leak, you start having flooding problems. The factory LT80 pet **** does not have an actual "off" position. Just on, pri (prime) and res (reserve). When the petcock is switched to on, the fuel only runs to the carb once the engine is started and is producing vacuum. Then vacuum acts on a diaphram on the back of the petcock that opens the fuel passage. "pri" is for Prime and should only be used when first starting the bike cold to allow fuel to fill the possibly empty bowl. Best bet is to test your petcock by removing the fuel line from the carb and switch the petcock to on. If fuel runs out, or even slowly drips out, replace it. Stick with a new factory vacuum operated petcock since these carbs will always flood if given constant fuel supply. You can save a few bucks and buy a true on/off petcock, but the first time you forget to turn it off and it sits for a few minutes, you can have flooding issues. Factory petcock is the right fix for this problem... Gas shuts off as soon as the engine stops running... Good luck!
Old Nov 28, 2010 | 09:23 AM
LT80's Avatar
LT80 Expert
2007 thread. LOL
The petcocks can be had for alot less than the 80 bucks.
You did explain it very well.
Old Nov 29, 2010 | 05:52 PM
rcastorena's Avatar
Ha, I didn't notice the dates! I just searched for carb leak and this is one I found. Where can you find the oem vacuum type petcock for much less than $80? I'd like to get one... Thanks!
Old Nov 29, 2010 | 06:30 PM
  #15
LT80's Avatar
LT80 Expert
My mistake. You are correct, a oem "vac" petcock is right up there in price.
I read it as a reg on/off petcock like on a dirt bike and such.
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
