Wheel Spacers
Old Sep 30, 2008 | 07:29 PM
  #41
WAATV's Avatar
Default Wheel Spacers"></title><script src=
I've thought about doing this myself and I would use coupler nuts. A coupler nut is like a really long nut, used to connect two threaded rods or bolts together. It's made as strong as regular nuts and bolts, and available at bolt and screw supply houses in a variety of sizes and lengths. Here's a photo:
My son's LT-A50's wheels mount onto studs. Nuts are then used to secure the wheel. I would use a coupler nut of the desired length and screw it onto the studs. This will give you a VERY strong extension. Then, instead of nuts, you'd use bolts through the wheel since the coupler nuts would change the gender from male to female.
Total parts: Three coupler nuts and three bolts per wheel. Add washers or use blue Loctite to prevent vibratory backoff.
Old Oct 1, 2008 | 05:41 PM
  #42
SAS MAYHEM's Avatar
WOW great idea, right now I'm having trouble fining them in a 5/16 x 18 3 inches long.
Old Oct 1, 2008 | 06:13 PM
  #43
WAATV's Avatar
I posted a response yesterday but it vanished and never showed up here. I'll try one more time.
Using my son's LT-A50 as an example, what I'd do is buy coupler nuts and matching bolts. A coupler nut is like a "really long nut", an internally threaded tube. They're specifically designed to join threaded rods or bolts, are very strong, and are available in a variety of sizes and lengths at fastener shops (regular hardware stores may not have much of a selection, but specialty bolt and screw shops will have them).
Here's a picture of a coupler nut:
Currently his wheels are held onto the hubs by studs in the hubs. The wheel sits over the studs and the lugnuts screw onto them. Remove a wheel, screw the coupler nuts onto the studs, and then reinstall the wheel using new bolts that pass through the wheel and screw into the coupler nut.
Result: Wider wheelbase using very strong components that don't cost very much and are available almost anywhere. No irreversible changes, either - you can remove the extensions at any time and go back to stock whenever you like.
Hope this helps!
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
