Stubborn LT80
Old Jan 9, 2012 | 01:36 PM
  #21
zeek624's Avatar
ok thanks i will try today and let you all no what happens
Old Jan 9, 2012 | 04:49 PM
  #22
LT80's Avatar
LT80 Expert
Good call wildcard!
Old Jan 10, 2012 | 09:25 PM
  #23
zeek624's Avatar
ok got spark gettin fuel cleaned carb not flooded still doesnt start whats the problem guys im going crazy new plug and gas also
Old Jan 11, 2012 | 01:21 PM
  #24
Wildcard0413's Avatar
Zeeke,
Last time a compression check was suggested. I don't see where you posted the results? You cant "feel" if it has good compression. Frozen rings or scored cylinder can cause friction and mistook for compression.
Need to rule things out instead of isolating the issue. It will make it much easier to help. These things are very simple machines and only require a few elements to run. Once your rule out what it's not your real problem will surface.
Check compression and get back to us
Old Jan 11, 2012 | 03:37 PM
  #25
LT80's Avatar
LT80 Expert
Plugged pipe?
Old Jan 12, 2012 | 11:17 AM
  #26
zeek624's Avatar
ok guys thanks for all the help i will get compression checked in next few days and i will take pipe off and blow compressed air through it and let yall no what happens then
  #27
zeek624's Avatar
the only thing that was odd he was ridding it about a few weeks before
Old Jan 12, 2012 | 06:20 PM
  #28
zeek624's Avatar
u no it had a plugged up pipe on it when i got it
Old Jan 13, 2012 | 01:04 AM
  #29
95wolv's Avatar
When I saw the title of this post "Stubborn LT80", first I thought someone was having a hard time convincing Jack of something..........
Old Jan 31, 2012 | 09:54 AM
  #30
zeek624's Avatar
i guess it compression problem i dont have a compression ester so i will move on to another project but thanks guys for the help
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Bergmann
Aug 13, 2015 03:51 PM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
