need lt80 long engine case
Old 08-16-2011, 06:00 AM
DAMONSQUAD's Avatar
Default need lt80 long engine case
ok guys, the worst case scenario has struck, i cracked the long engine case (left side) on my new 2000 lt80, does anyone have a spare they are looking to sell =(
Old 08-17-2011, 08:06 AM
DAMONSQUAD's Avatar
do you guys think if i have this welded it will hold up?
Old 08-17-2011, 08:47 AM
LT80's Avatar
LT80 Expert
I've had many welded.
Should be no problem.
I usually have a strap welded on in that area.
Old 08-17-2011, 11:41 AM
DAMONSQUAD's Avatar
ok great, the clutch cover is loose now too, so i guess i'm gonna check if the thread's pulled out or not.
can it be welded together, or do you suggest i pull the engine apart cuz of the heat?
Old 08-17-2011, 11:53 AM
LT80's Avatar
LT80 Expert
You should remove the motor.
The tranny will need drained or it'll blow fluid all over and the clutchs need to come out so the welder can clamp the case to the bench insuring that everything is flush/straight for the clutch cover.
The threads can be fixxed w/helicoil.
The re-enforcement I use:::
In front of the sprocket (where it cracks) I bend a alum piece sorta like /----\ to fit the case. Plus on top, 2 pieces::
1) along the top above the hole that the long pipe bolt goes thru (2" piece)
2) behind the side cover bolts and butts up against #1 (6" piece)...You may have to grind a lil on this where the pipe goes across.
1/4 x 1 alum.
Good to go.
Old 08-17-2011, 12:23 PM
DAMONSQUAD's Avatar
1/4 x 1 alum.
Good to go.
haha, thanks for the info jack, i'll just have it welded, i'm gonna buy a spare case just in case another one cracks.
Old 08-25-2011, 11:51 AM
gratefulfather46's Avatar
Default Cracked Case
I to have the same problem....My son cracked his case just last week...We threw all the goodies...pipe, shocks etc. on the backup only to find two tiny cracks in the front down tubes....Gonna get the tubes welded up so he can continue riding...finish tearing down the back up quad..send the frame and misc. parts to work with my brother in law for fresh powder and send the motor and clutches off for a bit of an attitude adjustment!....I would take Jack's advice on reinforcing the case...He's only trying to save you future headaches...Obviously I need to do the same..Nice to see that others are still racing the LT...We love ours and love beating up on the competition riding an antique...Cant wait to see the improvements after getting some work done!...Good luck to you!...Love to see some pics of some LT setups if anyone's gottem?!...Thanks...Jeff
Old 08-26-2011, 05:43 PM
LT80's Avatar
LT80 Expert
I put 1/4 square on the down tubes. never had any problem with them after that.
Old 11-02-2011, 06:58 AM
DAMONSQUAD's Avatar
finally made some progress, i bought that third lt80, thought it was a great deal for $200 for an 05, but it ended up being the most abused quad i've ever seen, but i DID buy it just for the good engine case, well of course, the case was cracked too, but very minor, so i had it welded, and started assembly, and paint per my kids request *sigh* lol.
here's a few pics to give this forum section some life
and here is my spare parts pile AKA bad purchase
and here's my warrior that doesnt run, and my friends 89rm 250 i'm re ringing
Old 11-02-2011, 07:10 AM
DAMONSQUAD's Avatar
and i'll post a video of early this summer to give you guys like me that are bored at work something to do
Quick Reply: need lt80 long engine case
