poralis 90 sportsman no spark
Old Apr 27, 2012 | 12:38 PM
bgbk2's Avatar
Default poralis 90 sportsman no spark
got a kids quad its a polaris but the chinese brand motor. anyway cant get a spark at all sattor and coil were changed already anyone got any other ideas
Old Apr 28, 2012 | 12:31 AM
LynnEdwards's Avatar
Electrical Expert
I went looking for, and could not find, a wiring diagram for your quad. With a wiring diagram there is much that can be measured I'm sure. Do you have a wiring diagram that you can send me? Or point me to a downloadable source?
I noticed this same post is in the polaris forum. Good... I'm hoping "Old Polaris Tech" will chime in. His posts about fixing polaris' problems have been really awesome.
Old Jun 5, 2012 | 03:52 PM
stilinsm's Avatar
Off of the CDI should be a black wire with a white stripe. pull back the plastic covering the connections, but leave the connection in tact. Now ground this connection to the frame or to the negative terminal of the battery and see if you have spark. This bypasses the upper controls. If you have spark, you have a problem with either the kill switch or the main key switch.
Jmuddin284
Jan 19, 2026 07:16 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
