LT 80 starting issues
Old Jun 23, 2012 | 12:01 AM
jasondemitri's Avatar
Default LT 80 starting issues
so, my 2005 lt80 is having trouble cranking. I replaced the battery (it was bad from sitting fot a long time). new battery installed, the thing barely cranked as if the cylinder is stuck. she barely gets turning before the CB pops in the rear. I removed the spark plug, plugged in my battery charger on 40 amps and the thing cranks perfect. remove the charger (still with the spark plug removed) she cranks alright, but still seems a bit slow. Add the plug and she seems as if there is too much compression to turn the motor over. So im thinking a starter...thoughts?
So, if it is the starter, where would you recommend i get one?
any help is much appreciated.
JD
Old Jun 23, 2012 | 07:02 AM
LT80's Avatar
LT80 Expert
They sell clones on ebay.
A Suzuki starter is $$$
chinkapin
Jul 14, 2016 06:58 AM
buckshit
Sep 24, 2015 08:49 PM
BEEFKING69
Jun 17, 2015 12:38 AM
Steven Bandemer
Jun 9, 2015 08:50 PM
1000gade
May 27, 2015 12:37 PM
