LT50 clutch issuehe key had gournd
Old Sep 28, 2012 | 07:49 PM
fastcar01's Avatar
Default LT50 clutch issuehe key had gournd
I picked my boy up a 84 LT50. The clutch was grabbing a bit, so I opened it up and saw only one thick (3mm) thrust washer behind the clutch, and none inbetween the shoe and drum. I orderd the thin one (1.5mm). I had to clean up the spacer that goes in the drum a bit as the key had chewed it up. So now when I put the 1.5mm thrust washer behind the clutch as shown in the micro fische, the gear on the clutch drum rubs against the bearing reaatiner. I put it back with the thick washer back there and it is grabbing a bit. Any idea what would cause it? Next time I open it up I am going to have to look at the retainer I suppose? The thick spacer should go between the clutch drum and shoe and the thin one behind right? Should the gear ride above the retainer, or clear it?
Thanks
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
