Lt80 clutch
Old Oct 25, 2012 | 08:36 PM
Brian Adwell's Avatar
Default Lt80 clutch
Probably been asked a million times but here goes:My first mod was to remove 2 front rollers now ive been reading about how to lighten up the rear shoes,what exactly does that help?take off,top end,or to get in the higher revs quicker?I already went to a .90 main,Boysen reed,porting reed cage as we speak,deleated oil injection,removed 2 rollers,wheel spacers aluminum DWT wheels,snow hoggs,aluminum handle bars,acerbis hand guards,shaved front fenders,UNI air filter just wanting to do as much as possible before this week-end! THANKS!
Old Oct 29, 2012 | 07:49 AM
DAMONSQUAD's Avatar
the clutch mods help keep the quad in its power range, i can't say much for a stock engine because i've never modded a clutch on a stock engine, but with a modded engine, it makes it scream!!!
Old Oct 29, 2012 | 08:04 AM
LT80's Avatar
LT80 Expert
It helps a stock motor do the same but will not gain any speed.
Old Oct 29, 2012 | 12:46 PM
Thanks guys I was just doing all I could to it but I didnt want to hurt the performance of it by lightening the rear shoes,so it shouldnt hurt nothing? Im going to have the national port done sometime this winter.
Old Oct 29, 2012 | 03:12 PM
LT80's Avatar
LT80 Expert
It'll be fine.
If it effects speed, add a roller.
Old Nov 2, 2012 | 12:58 AM
Thanks guys, went to wal-mart got me a digital scale and got the rear shoes down to 180g. It didnt hurt top speed any but helped it get up in its power range quicker,so I just left 2 rollers out. Whats next???
Old Nov 2, 2012 | 08:08 AM
LT80's Avatar
LT80 Expert
Add a base gasket and remove the head gasket.
Old Nov 3, 2012 | 12:10 AM
So after I remove the head gasket do I need to use some sort of sealer?How do I know if the head has already been shaved?
Old Nov 3, 2012 | 08:16 AM
LT80's Avatar
LT80 Expert
You can use a lil silicone if you want.
When I shave a head, I mark it.
Unless there is a reason to believe the motor has been worked on, I'd pressume it's a stock head.
Old Nov 3, 2012 | 10:37 AM
Could I remove the head gasket without adding another base gasket? Or would it put the head to close to the piston?What's the benefit of two base gaskets and no head gasket? Seems like compression wouldnt be changed unless it changes port timing?
buddieboy
Dec 9, 2016 05:50 PM
QuadRiders
Oct 22, 2015 04:13 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
merryman
Sep 19, 2015 03:15 AM
