02 arctic cat 2-stroke problems
Old Feb 13, 2013 | 03:52 PM
camaro1969's Avatar
Default 02 arctic cat 2-stroke problems
starts fine idles great sometimesit takes off great let off gas and take off again wont rev up sometimes it does but takes for ever?????????
Old Feb 13, 2013 | 04:46 PM
LT80's Avatar
LT80 Expert
Clean the carb.
Maintenance the clutchs.
Old Feb 13, 2013 | 04:50 PM
camaro1969's Avatar
took carb apart it is spot ess n side looks like new. Is he clutch a big deal to do ever tore into something this small.
Old Feb 13, 2013 | 05:25 PM
LT80's Avatar
LT80 Expert
Clutchs are sorta easy on the scooter motors.
Maybe check to see if the pipe is plugged.
Wouldn't hurt to know what the compression is too.
Old Feb 13, 2013 | 06:13 PM
camaro1969's Avatar
80 psi seems low to me
thanks
Old Feb 13, 2013 | 07:57 PM
camaro1969's Avatar
Got home fires right up runs great for about. 1 min then what's to die let off gas idles down and runs smooth if I lift the tires off the ground revs up good. Also after it sat for about 5 min leaking alittle out of the tube
Old Feb 13, 2013 | 10:57 PM
LT80's Avatar
LT80 Expert
80 is low. You need a new piston/bore.
Unless the head gasket is leaking.
Just to make sure, you did remove both jets and make sure all was well?
Nondem
Feb 22, 2020 12:20 PM
greg74
Sep 10, 2019 03:03 PM
NatePerz
Jul 27, 2015 03:27 AM
Gtsordo
Jul 13, 2015 10:38 PM
Jul 7, 2015 11:00 PM
