Lt80 gas/oil mix problems
Old Feb 19, 2016 | 06:07 PM
Poolshark588's Avatar
Default Lt80 gas/oil mix problems
My sons LT80 seems to load up and stall out after he is riding for a little while. About 1/2hr. Currently I am running 32:1 premix. (Injector doesn't work). He doesn't go too fast at the moment. I have it governed down. He is still new to it. With it governed down he just doesn't rev it up enough. When I get on it I get it going pretty good. I just don't want to have to stop every 20 mins to clean it out. Should I change the mix ratio? Or maybe a hotter plug? Any help would be appreciated
Thanks
Old Feb 20, 2016 | 08:23 AM
LT80's Avatar
LT80 Expert
You can try a hotter plug but with it governed down, it'll prolly continue to load up.
Old Feb 20, 2016 | 08:49 AM
What about changing the mix would that help?
Old Feb 20, 2016 | 09:11 AM
LT80's Avatar
LT80 Expert
You could try 40:1
What oil are you using?
Old Feb 20, 2016 | 09:30 AM
Just a general 2stroke oil. What would be a good choice for oil?
Old Feb 20, 2016 | 09:52 AM
Zrock's Avatar
Super Quad Patrol
did you go in and ask your dealer what a 2 stroke mix is? I would think 40-1 or 50-1 would be good..
Old Feb 20, 2016 | 12:51 PM
Fasteratv's Avatar
Changing the fuel/oil ratio is unlikely to help. About the only thing that I could recommend is jetting it a little leaner. Or you open up throttle, get it cleaned out for him, ( ring it out a little ) and then re-adjust the throttle for your son to ride.
Old Feb 20, 2016 | 02:41 PM
LT80's Avatar
LT80 Expert
To answer this question, I like synthetic oils.
Red Line, Klotz R-50, and prolly the most available oil, Maxima Super M. Any of those at 32:1 or 40:1
You can go with amsoil if you want to try a 50:1 oil
Bergmann
Jul 30, 2016 03:17 PM
RUNMYTA96
Feb 27, 2016 07:24 AM
Ckieffer29
13
Feb 22, 2016 03:40 PM
DennisZ
Feb 22, 2016 12:09 PM
LateStarter
Feb 19, 2016 10:05 AM
