LT80 Cold Start troubles
Old Feb 18, 2019 | 08:01 AM
DeLaSwim's Avatar
Default LT80 Cold Start troubles
Hello everyone. My LT80 is having a rough time starting below 32 degrees. Yesterday it was 25 degrees and it wouldn't fire. When it's above freezing, no issues what so ever. I'm not sure what I can do to make it more reliable in cold temps. Maybe a new spark plug????
Any suggestions are welcome.
Old Feb 19, 2019 | 02:38 AM
Bad starting is usually a sign of low compression. I would do a compression test and fit a new plug (just in case). Under 90psi and the "top end" is getting towards needing a rebuild. Any tiny water droplets in the fuel can freeze, but if there is water in an LT80 carb, it probably won't start anyway.
Old Feb 19, 2019 | 07:22 AM
LT80's Avatar
LT80 Expert
When we raced in the cold, I had to have a torpedo heater with me to warm them up.
Old Feb 19, 2019 | 08:00 AM
DirtDevil101's Avatar
so...being a sled guy I'd suggest you jet it all around a bit fatter (rich) for cold weather use...that'll help with the real colds start and will keep you out of a lean condition as the temps drop...the main is pretty rich from the factory...so that one should be ok...but I'd still do a plug chop at WOT just to make sure it's not running too lean...my $0.02
Old Feb 19, 2019 | 09:03 AM
DeLaSwim's Avatar
My top end rebuild was done 16 hours of run time ago. I think I'll try a new plug and hope for the best. Any idea of how long a rebuild lasts?
Old Feb 19, 2019 | 10:21 AM
LT80's Avatar
LT80 Expert
Not long with a dirty air filter. LOL The variables: air filter and oil.
If its a Suzuki cylinder/piston it should last a lot longer than 16 hrs. If it's a china kit, never know.
Anyways, I'm with Merryman on the comp test. <---- Always tells a lot.
They are a cold blooded beasts.
Old Feb 20, 2019 | 09:22 AM
Zrock's Avatar
Super Quad Patrol
have you checked choke operation...
Old Feb 20, 2019 | 12:38 PM
DeLaSwim's Avatar
The rebuild was completed with OEM Suzuki rings, piston, and everything else that gets replaced during a top end rebuild. The choke works fine. I'm going to go out today and give it another try. Current temp in N. KC is 33; we'll see what happens.
jasondemitri
Apr 14, 2015 02:56 PM
Fiveflat
Aug 15, 2014 03:48 AM
lusty
Sep 19, 2005 07:19 PM
WilsonCo
Feb 21, 2005 03:17 PM
shastadog
Jan 26, 2004 09:59 PM
