cannibal on its way & needs help
Old Jul 27, 2005 | 12:41 AM
Proflow's Avatar
Default cannibal on its way & needs help
Hey guys, Great forum. I have a question for you pros on a quad I recently purchased on e-bay. (It'lll be here Fri.) OK here goes. This is an all stock 02 cannibal that the prior owner claims needs a fuel pump. Story is the pump will prime, start bike & quit. Guy claims he ordered another used & same thing. Ordered another used from same person & the fitting threads were trashed. My first thought was probably a bad relay or whatnot but he said he bench tested w/jump box & no fuel flow. He never did say about testing the one w/bad threads. Could I swap housings from one to next if the one works ? How about cut & tig it ? Is the Ford Ranger pump really an alright way to go if I need to replace ? I read also of one from Summit. Should i wait for the latest d&m to be released or buy whats available now ? Kinda like the idea of possibly being able to switch multiple maps on the fly. (is that right ?) Still learning. I plan on doing all updates including stroker while its apart. Maybe 500 if available. Sorry for long post , just siked about new machine !!! Thanks again---Proflow
Old Sep 10, 2005 | 04:04 PM
TheNadine's Avatar
Send it to ATK, they will stroke it to a 450 and fix the 4'th 5'th lag for under a G
Old Sep 10, 2005 | 07:19 PM
WISTECH's Avatar
Switching maps on the fly is done with the Map select kit. You can do it with a laptop with the D@M kit but not while riding. The Ranger fuel pump works fine. Check fuel pressure. Do you have the mc500 computer or the mc1000 . Only the mc1000 can switch maps. The mod nadine is talking about is the motard 5th gear which narrows up the gap between 4th and 5th gear . ATK does not stroke engines. They only use larger expensive bore kits. Falicon and Timbomoose storke the cranks. The motard gears are pointless with a stroked/ported engine because there is so much more power that you will never notice the gap.
Old Sep 10, 2005 | 07:42 PM
Proflow's Avatar
Thanks for the reply, what all is done ? Do they actually swap the crank & rod ? Id like a different 5th, thats for sure.
Old Sep 10, 2005 | 07:56 PM
Proflow's Avatar
Woops, didnt see your post Wistech, thats what I thought on the ATK deal. Im not sure why this post resurfaced, I started it back in July. Thats cool, since then Ive done the Ranger pump, cleaned injectors & swapped out the spun flywheel. Oh yeh, HMF slip on too. She rips !!! If I had one complaint it would be it fouls plugs easy. Im running the moto/speed map. (got a d&m) Sometimes I forget to fire & walk away for a minute before touching the throttle. The next plug I put in maybe an 8eix instead of 9. I Just won the last Speed that went on e-bay for my wife also, its on the way from Missouri. Thanks all-----Proflow
Old Sep 10, 2005 | 09:19 PM
WISTECH's Avatar
Fouling plugs. Drop your offset by .2 and raise your flowrate by 100 .That should lean it out. Do a throttle recalibration for better cold starts.
Old Sep 11, 2005 | 01:15 AM
TheNadine's Avatar
Jeez wistech, sorry man...Stroke and bore got mixed in my head. Im thinking about sending my engine in for the transmission and the 450 kit
Old Sep 11, 2005 | 01:18 PM
WISTECH's Avatar
Sorry man just needed to corrct you on that. I would only use the 5th gear mod on stock engines. You will regret it if you increase power . Unless you run in sand all the time you will be looking for much taller gearing .
Old Sep 11, 2005 | 03:39 PM
TheNadine's Avatar
I dont really need the 5'th thing, i have enough pickup to compensate, i still want 17 more cc though
mtecate4g
Oct 19, 2002 12:14 PM
SparkyEX
Feb 6, 2002 12:01 PM
OregonMXracer
KTM
10
Feb 2, 2002 06:33 PM
SparkyEX
KTM
10
Nov 28, 2001 04:35 AM
Kodiak01
KTM
Oct 21, 2001 07:47 AM
