stiff clutch on banshee!
Old Dec 24, 2005 | 01:53 PM
bansheemike's Avatar
Default stiff clutch on banshee!
my banshee clutch is sooo stiff.. is there any ways to make it easier to pull??
Old Dec 24, 2005 | 05:53 PM
DriverDoyle's Avatar
Well It Prob not your clutch... Try changing your clutch cable first or spraying some wd40 in one end of it and work the clutch. Couse the only other thing it could be is your clutch springs. And if there working right you dont want to mess with them..
Old Dec 24, 2005 | 05:54 PM
Ok you got the barnett clutches i have them too. And they are way stiffer than a stock clutch...You Still could have a dry cable...
Old Dec 24, 2005 | 06:36 PM
I have a brand new cable on it so I dont think thats the problem.. probably the clutch springs.. I was thinking about a hydraulic clutch system and easy pull levers.. anybody use those?
Old Dec 24, 2005 | 11:41 PM
JayMoneyDubs's Avatar
Hey I have a stiff clutch on my 250r and my girlfriend just got me the moose easy pull clutch system. I installed it thursday and it really works you can set it for 20, 25 or 30% more leverage. it is only 32$ and well worth it I think anyway
Old Dec 27, 2005 | 07:01 PM
Bubba297's Avatar
The barnett clutches come with 6 stock replacement springs and 6 stiff springs. With a stock or mild performance motor we will run 3 heavy springs in a triangle pattern. It helps put more power to the ground but also is also easier on the hand. I run all stiff springs with an extra plate stacked. It is a nice firm clutch[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 27, 2005 | 07:09 PM
I had 3 of the light springs and 3 heavy springs in and the clutch slipped off the line... so I had to go back to the heavy springs
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
