06 Sportsman 500ho
Old Jun 21, 2011 | 10:09 PM
There is a HONDA section and just click on it. You will see where to click on to start a new thread! They can probably help you better,unless some one here can jump in and help?? Hope this helps OPT
Old Jun 21, 2011 | 10:13 PM
Originally Posted by Pinkfloyd042
I tried the speedo check and nothing came up. Why wouldn't it check it.
A lot of times just a short,bad connection,etc won't throw a code on the speedo! Frustrating I know,but this what happens with efi systems,hard to be a "shade tree" mechanic any more! I'm just able to comment on what happened the most on the efi systems,and the map sensor harness kit was the most common problem we had.There is also the crank sensor wiring, tps wiring that could be the cause. As far as the sensors themselves,they usually were not the problem,JUST the wiring. If you read the "sticky" posts in this section about the sensor wiring,it may help! OPT
Jmuddin284
Jan 19, 2026 07:16 AM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
79hugger
Aug 30, 2015 02:21 PM
pro94lt
Aug 20, 2015 10:02 AM
