99 Sportsman transmission troubles.
Old Feb 6, 2014 | 12:37 PM
gwhunter6629's Avatar
Default 99 Sportsman transmission troubles.
i have a 1996 sportsman and the trans pops out of high ad reverse gear , i would like to know what other years will bolt right in i have seen 97 look the same but the rear brake rotor is bolted on and mine is not would this still work
thanks
Old Feb 6, 2014 | 04:34 PM
Usually not the transmission but worn out internal shift box parts. You can try to adjust the linkage and see if it helps along with making sure the belcranks(levers) on the transmission are tight. Have it in neutral,loosen the lock nuts on the linkage ends,remove both linkages from the shift box levers. Adjust the linkage ends to where they drop straight into the shift box levers with NO resistance,the tigten the lock nuts and two nuts securing the linkage. While you have the linkage arms off see if there is a lot of free play back and forth on the shift lever while still in neutral. If there is,adjusting may or may not help.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Feb 7, 2014 | 07:16 AM
I have all ready tryed to adjust the link rods when i did that it would stay in one gear and not the other . i can get in to gear at idle then when i give it gas it pops out
Old Feb 7, 2014 | 11:04 AM
Another way to tell is to disconnect the linkage from the transmission belcrank,use vice grips to manually place it in gear and then see if it jumps out of gear. If it does then you possibly have a shift fork problem or engagement dog wear on the slider gear along with the main drive gear.If it stays in gear then it's probably wear on the shift box internal components that need to be addressed.
Old Feb 7, 2014 | 02:38 PM
thanks i will try that if it is the shift fork or the slider gear would it be cheaper to get a good used trans or replace fork and gear i have seen trans on ebay for about 250 and will a 97 or a 99 trans work in a 96
Old Feb 7, 2014 | 03:57 PM
Got to be careful on used parts,could be in worse shape than yours. You'd have to pull the transmission any way if that is the problem,so just check yours out. A lot better than installing another one and possibly having problems again.
Old Feb 8, 2014 | 01:35 PM
how big of a job to tear in to the trans do i need to know anything to tear it down
Old Feb 8, 2014 | 02:21 PM
Down load this pdf service manual and it will show what's involved in this transmission. Not one of my favorite jobs as there are a lot of parts along with a couple chains,etc.http://gh-ftp.com/ORV%20Manuals/Pola...e%20Manual.pdf
greg74
Sep 10, 2019 03:03 PM
cornermike
Aug 10, 2016 06:47 AM
oldschool64
Aug 12, 2015 07:13 AM
house1
Aug 9, 2015 10:49 PM
bikedad3
Jul 2, 2015 02:15 AM
