RZR first time in the snow.....Throttle STUCK WIDE OPEN !!!!
Old Jan 2, 2008 | 12:52 AM
kyledvor61's Avatar
Default RZR first time in the snow.....Throttle STUCK WIDE OPEN !!!!
My throttle also stuck too!! It was sitting out and i fired it up, no problem. Went into reverse but missed and hit neutral but didnt know it. I tapped the gas and my throttle stuck wide open. If i were in reverse I would have wound up in the lake. I went to fire it up again and the throttle was wide open. Same thing 3 times. It was so cold the throtle cable was stuck. Got it in the garage and warmed up and wiggled it and it was fine. Hope this doesnt happen again.
Old Jan 2, 2008 | 05:12 PM
GregV's Avatar
It sounds like a good canidate for a recall to me.
Old Jan 4, 2008 | 12:07 AM
kyledvor61's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: GregV
It sounds like a good canidate for a recall to me.</end quote></div>
I wonder how any other people have had issues with it too. If enough, then yes it would be a recall.
Old Jan 9, 2008 | 09:09 PM
beermanjoe's Avatar
Had mine out in the snow,runing through ditches full of water no problems.It was about 18 deg.
Old Jan 15, 2008 | 10:59 AM
  #15
GregV's Avatar
OK, what I found is that the throttle cable is completly sealed at the engine so if water gets in, it's not going to get out by itself.
So, if you get in water above the pedal and water makes it's way into the top of the cable you will need to inject some cable lube or something to get rid of the water. I had been in Kentuky and had water above my gas pedal. The moisture stayed in there and when I drove it out of my heated garage into the 15 degree weather, it didn't take long for it to freeze.
Polaris replaced my cable under warrantee ( there was nothing wrong with it visibly ). When they put the new one on, they filled it with cable lube to prevent moisture from getting back in.
So, thanks to Polaris for standing behind your products. I have purchased a lot of units from this dealer and have sent many friends and family their way, so they treat me pretty well.
BUT, remember guys.....make sure that you lube you cables. ;-)
Old Jan 15, 2008 | 05:53 PM
  #16
Nightclerk's Avatar
I had it happen to me,thawed it out went to use it latter it was frozen in the idle position. Took it to the dealer & they injected lube in it & has been fine for over a month now.
Old Jan 25, 2008 | 04:39 PM
  #17
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Make sure you guys check all of your fluids on the razors I heard they had allot of problems with sending them out with only parcial fluids.
Old Dec 3, 2008 | 08:00 PM
  #18
oscanator's Avatar
Default RZR first time in the snow.....Throttle STUCK WIDE OPEN !!!!"></title><script src=
we need everybody that has had this problem it report it to the product safety administration you can go to there web sight and fill out the forms tacks about ten minutes
Old Dec 21, 2008 | 11:58 PM
  #19
4strokemurder's Avatar
i lol'ed so hard when you said your kids hit the back tire LMFAO
Old Nov 12, 2013 | 10:45 PM
  #20
Darry Goertzen's Avatar
Default Had it happen to
Mine got stuck in reverse and I was two inches from going backwards over an imbankment but first reaction was apply brakes and in turn shattered my front diff pissed me off hope it becomes a recall
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
sara durrant
Jul 6, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
