Getting ride of oil injection, good or bad?
I am thinking of getting ride of my oil injection on my 02 TB. Thew oil light seems to be coming on lately.
1) What is the easiest way to disconnect?
2) What pre-mix rate should I use
3) Do I use the same oil I used for injection
4) How many ounces of oil per gallon of fuel?
Thanks
Thanks
It is pretty simple to go to pre-mix. Go to www.hotseatperformance.com and get an oil injection block off kit. Everything youi need is included except for a throttle cable, which you can modify yours by just tying up the oil cable somewhere out of the way, or www.hpd-inc.com has the cheapest aftermarket single cable I have found. You should run between a 32:1 and a 50:1 pre-mix ratio, I would recommend 40:1. You can use the same oil you use for injection, but the regular Polaris Blue oil is what most everyone uses, it is cheaper and works great for pre-mix. The easiest way to mix your oil correctly is to get a ratio bottle somewhere. Alot of places sell them and they are very cheap. I use a Ratio Rite jug that I bought from http://www.rockymountainatv.com I know that Kmart and Wal Mart also sell mixing bottles. Good luck and ask if you have any questions.
hoopduerr
06-02-2015 09:01 AM
hoopduerr
06-01-2015 08:22 PM
