Clutch springs
Old Jan 7, 2004 | 09:09 PM
ftwflh's Avatar
Default Clutch springs
I am going to try the springs that I had in my 425 Magnum.White Polaris primary and a blue Aaen secondary set at 2-2.I plan on leaving the motor stock for now but when I pipe and jet it I may change to a differant set up.
Old Jan 8, 2004 | 06:56 PM
pulverized's Avatar
So, if I leave the secondary spring and weights alone but change the primary spring I should have a good gain in performance?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 8, 2004 | 07:38 PM
ftwflh's Avatar
If you are just going to change the primary spring get you a Polaris white and it will improve the response enough to tell the differance on take off.But the secondary controls the back shift and if you ride trails alot that one is noticable too.
Old Jan 8, 2004 | 08:07 PM
pulverized's Avatar
ftwflh, Thanks for the reply, I want to just get a primary for now and work on getting a clutch kit later on. I'm modification poor from my V at the moment so my better half told me to take it easy for a while
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 8, 2004 | 08:19 PM
  #15
pulverized's Avatar
Also, is everyone buying the springs from the manufacturer or is there a website that has them for less?
Old Jan 8, 2004 | 08:26 PM
  #16
ftwflh's Avatar
I forgot to tell you in that PM that holds if I like the yellow [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 8, 2004 | 08:31 PM
  #17
pulverized's Avatar
Sounds good. Thanks[img]i/expressions/face-icon-small-smile.gif[/img]
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
