how about the clutch???
Old Feb 1, 2004 | 03:09 AM
TooFastIsBarelyEnough's Avatar
Default how about the clutch???
I got the flywheel off ok. now how about pulling the clutch off the engine?? any info ?? once again it would be much easier if I had the manual. thanks for any help. I want to pull the whole engine out but I think I need to pull the clutch off first?>
Old Feb 1, 2004 | 03:54 AM
fredbear92's Avatar
You will need a clutch puller to do this.Someone will be along that has made a puller.Or you can buy one from the polaris dealer.Around 20.00 I think.
Old Feb 1, 2004 | 10:09 AM
CED's Avatar
CED
If you can find an all thread 3/4 fine thread rod ,put two nuts on it jam them together.This would work.I use a trailer ball that has a 3/4 fine thread shank on it.You will have to put something inside the hole to be able to push on as you tighten down.
Old Feb 1, 2004 | 05:58 PM
anyone else have info on pulling the clutch??
Old Feb 1, 2004 | 06:47 PM
Polaridoo's Avatar
That primary clutch is too expensive to use anything other than a clutch puller or possibly the all thread idea. I would NOT use a conventional 'gear puller' or apply any heat.
Old Feb 1, 2004 | 09:59 PM
xxxracerxxx's Avatar
ya it says in the manual to use a puller but the driven or secondary clutch you can pull that off by hand
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
