Powershift
Old May 9, 2004 | 09:38 PM
Sobemelahead's Avatar
Default Powershift
how do you powershift?????
Old May 9, 2004 | 10:16 PM
bready04's Avatar
Default Powershift
dont use the clutch and keep the gas goin
Old May 10, 2004 | 07:14 AM
Hozed's Avatar
Default Powershift
i suggest not doing this...
Old May 10, 2004 | 12:43 PM
bready04's Avatar
Default Powershift
either do i, i havnt tried it on my pred but i heard the pred doesnt like it
Old May 10, 2004 | 01:23 PM
Flynbryan's Avatar
Default Powershift
.....REALLY don't like this. Polaris "says" this is the reason for the demise of the 03' trannys. I question that its the sole reason, but it certainly does contribute...... Don't do it.
Old May 10, 2004 | 01:44 PM
mistertinker's Avatar
Default Powershift
then shellout lotsa cash for tranny rebuild
Old May 10, 2004 | 02:13 PM
sp600towtruck's Avatar
Default Powershift
Why don't you just try and "speed shift". Like I used to do in my old Trans Am, keep the throttle wide open when you depress the clutch and shift, just make sure you do it fast so you won't blow it up or bounce of the the rev limiter. I could speed shift my '83 Trans Am with 305 and 5 speed and even bark the 3-4 shift at 80 mph and run a low to mid 14 second quarter with the car all stock.
p.s. you should practice at this before you run it full tilt.
Old May 10, 2004 | 10:10 PM
Redbullssg's Avatar
Default Powershift
THis is where they all go WRONG. You don't keep on the gas and shift!!!! You blip the gas just a bit to release the forward pressure on the gears, just for a moment as you shift, like just for milliseconds and just enough to release the pressure. It is very simple! You WILL damage your tranny or any tranny if you don't blip the gas...
m44
May 20, 2010 10:19 PM
momo951
Apr 16, 2009 08:56 AM
Sobemelahead
May 9, 2004 10:42 PM
oddmetal
May 10, 2003 02:53 AM
Maxima
Oct 31, 2001 07:40 PM
