Sp500 Vs. Sp500H.O
Old Sep 1, 2004 | 11:50 PM
Crit's Avatar
Default Sp500 Vs. Sp500H.O
Hey
I was wondering what the difference is between the sportsman 500 and the high output edition?
Will eather of these machines lift the front end to do wheelie? Thanx
Chris
Old Sep 2, 2004 | 12:33 AM
BigBadScrambler's Avatar
The HO has 20% more power. Both m achines will do a wheelie, with a little effort[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 2, 2004 | 12:42 AM
Crit's Avatar
Do you know what is done to the quad to make it produce 20% more power? (bigger pistons, valves, etc)
Chris
Old Sep 2, 2004 | 12:45 AM
Different cam, bigger carb, and a slightly larger exhaust from what I can recall
Old Sep 2, 2004 | 12:48 AM
Crit's Avatar
Sweet , sounds good enough to buy 1. thnanks for your help
Old Sep 2, 2004 | 12:53 AM
Happy to help[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 2, 2004 | 12:01 PM
FormulaLT1's Avatar
are you sure they have a different cam? i thought they just had a larger carb. actually there's a little more power with the HO, but not that much. I doubt it's 20%
Old Sep 2, 2004 | 03:29 PM
Elbongo's Avatar
BBS is right. They have a more aggressive cam and a larger carb. 40mm Mikuni vs 36mm Mikuni. I thought I've heard that the HO also has a little bit different clutching than the standard SP500. The HO makes 20% more peak horsepower but loses some low-end power. The bigger carb would probably be the main reason for less low-end power.
Aug 21, 2015 01:46 AM
FireFighter
Jan 7, 2001 04:50 PM
alaskaweasel
Aug 24, 2000 08:49 AM
wilddave
Dec 5, 1999 06:41 PM
cstark
Sep 11, 1999 01:21 AM
