Maintance info for a TrailBlazer 250
Old 11-08-2004 | 11:45 PM
rprice6's Avatar
Default Maintance info for a TrailBlazer 250
I bought a 2001 TrailBlazer 250 used several months ago and was wondering if anyone could tell me what kind of maintance I should be doing to it so that I can keep it in good running condition. It didn't come with a manual and I didn't know what type of maintance and how often it should be done. Any help would be appreciated. Thanks
Old 11-09-2004 | 01:48 AM
jimmypsp700's Avatar
You can download or print off a manual HERE for free.
Get a chain tensioner and keep up on the fluids.
Good luck!
Old 11-09-2004 | 08:35 AM
scootergptx's Avatar
Supersock
Hired Gun!
Grease the zerks, keep the chain lubed, check the tranny fluid, check the spark plug,make sure you oil level is up and wash it. I usually grease ours at least after every other ride. Depending on what type of riding you do, that may vary. Drain and fill the tranny annually. I keep two spark pugs and usually change them after each ride (overkill, but I always know if it's running too rich or not). Spray the chain before each ride. Make sure you use a lube that is safe for O-ring chains. If you pressure wash it, do not spray the chain, it can blow out the O-rings. Look on Ebay for a service manual, should be able to find one for under 20 bucks. Air in the tires and gas in the tank and you're good to go.
Old 11-09-2004 | 08:46 AM
Raziel's Avatar
Hey guys, how well does the Trailblazer 250cc 2 stroke accelerate when compared to the 4 strokes such as Suzuki LTZ250 and the Honda 250EX. [img]i/expressions/face-icon-small-smile.gif[/img] [img]i/expressions/face-icon-small-smile.gif[/img]
Old 11-09-2004 | 09:13 AM
Supersock
Hired Gun!
A stock Trail Blazer won't win any races. Pipe it, jet it and put a clutch kit in it. You'd be suprised what these things can do when they're modded.
Old 11-09-2004 | 05:17 PM
tbsleeper's Avatar
its close to a 250ex stock
Old 11-09-2004 | 08:09 PM
ftwflh's Avatar
DONT FORGET TO KEEP THE AIRFILTER CLEAN
Old 11-09-2004 | 09:53 PM
rprice6's Avatar
Thanks for all the great info. I will have to check ebay for a manual. Thanks for the feedback.
buddieboy
12-09-2016 05:50 PM
exmotocrosser
09-26-2015 08:18 AM
woodthings
09-25-2015 05:58 PM
Todd C Wadas
2) Chassis problems..
09-23-2015 11:31 PM
chewy78
09-08-2015 10:37 AM
Quick Reply: Maintance info for a TrailBlazer 250
