CV Joints
Old Oct 6, 2000 | 12:55 PM
  #31
walexa's Avatar
screamin4wheeler,
Spacers for the front springs on a polaris is also known as a "LIFT KIT". To cure your problem, call Gene's Polaris @ 1-800-544-0694. They sell spacers for the front. They lift the front 1.5 inches, and cured my fender rubbing on the sp500 I had. No problems with drivetrain with the "lift kit" on.
Old Oct 6, 2000 | 12:59 PM
  #32
walexa's Avatar
Greg,
I have an internally broken cv joint. I cleaned it up, but threw the ***** away. I still have the inner piece that fits on the shaft. With just that, could a cv rebuilding place repair that joint? Thanks in advance.
Old Oct 6, 2000 | 02:12 PM
  #33
gregsims's Avatar
Yes they can. They will replace that inner race also. Most of the CV shops around here stock that cage. If your local place does not, they can get it in quickly. I think Rockford CV makes it.
What you might want to do is look on line and find a place that will sell you just the cage and *****. That will only cost you araound $15. I have never done this but I know there are peoeple that have. The cage is what breaks and you can buy those for around $10. For that price you might want to stock up. The only reason I have not done it that way is that I would probably have to send in the good race on the other side. (Pain in the ###) If no one local will do it for you, you can call WC Supply in Tyler Texas. They will be happy to do it for you. $69.99 That price includes everything (*****, race, cage, boot, clamps, grease... not to bad)
Good luck. If you lived closer I would be more than happy to help.
Greg
PS How did you break it? Tires? Lift? Reverse?
Old Oct 6, 2000 | 03:08 PM
  #34
gregsims's Avatar
Walexa,
You only live about 2hours 45 minutes(or less) from FWP. You need to show up for one of the big rides.
Greg
89Lt250r
Sep 7, 2015 07:53 PM
Ferhat Durakovic
Aug 26, 2015 07:04 AM
pro94lt
Aug 20, 2015 10:02 AM
toonces
Aug 13, 2015 12:40 PM
Peter_
Jul 18, 2015 07:06 AM
