trailblazer clutching?
TK its pretty easy just pull the cover off, theres about ten screws holding it on.
then the clutch spring is held in by one lasrge bolt and eight smaller ones, remove these, change spring and reverse removal process. just be sure you get the clutch cover seal in good or you willl get water in the clutches making them slip.
my description may not have been the best but its real straight forward when you get the cover off.
I thought the blue green came on the 99 sports? the spring itself is not totally white just the tip of it looks dipped in white paint.
also check epi and dalton they have some good aftermarkets.
