anyone know how to remove the clutch on a 97 sportsman 400l 4x4
I can't figure out how to remove the clutch on my 97 sportsman. I need to remove it to get to the last bolt on the starter so I can install a new one. If anyone knows how to get the clutch off I would greatly appriciate the help.[img]i/expressions/face-icon-small-disgusted.gif[/img]
I got mine off without a puller. take a strong screwdriver and jam it in the clutch so when you try to wrench the bolt off the screw driver will keep it from rotating. once the bolt is off it should be fairly easy to remove. may take a little pulling and jiggling to get off, but it will come off. If you have no idea what im saying, go spend ur money on a puller. haha
KimSJoh
14
07-18-2015 07:20 PM
