Heel Clicker Clutch Mod?
Old Oct 25, 2005 | 06:45 PM
MNScrambler's Avatar
Default Heel Clicker Clutch Mod?
Is there anything I could possible harm by doing this? Because if there is a possibility of something going wrong, I'll mess it up. What have people done to keep metal filings from getting into their clutch? How much material have other people had to remove on their clutches?
Old Oct 25, 2005 | 07:08 PM
SPORTSMAN70003's Avatar
I'm a member over at the ATVQUADSQAD where you can buy the kit at a discount and its talked about alot there. Alot of people have installed this kit and not once have I heard of anyone messing up with the filing of the clutch. Like I have said a couple of times its a very small amount that you file and will NOT hurt anything.
Old Oct 25, 2005 | 07:17 PM
Also with the metal shavings you can blow them out with compressed air. Have you looked on the heelcliker web site I think it shows how much material they removed. I wouldn't grind on the weights.
Old Oct 26, 2005 | 02:54 AM
jimmypsp700's Avatar
Its just a little "flash" or extra material at the parting lines you'll be removing.
DO NOT file on the weights.
Jim
Old Oct 26, 2005 | 12:08 PM
  #15
What is the purpose for the metal nut in the kit? I've heard that you should NOT install this and leave the stock nylon one in. Do you have to have the spider removed in order to install the nut?
Old Oct 26, 2005 | 04:17 PM
  #16
Since you have a Non- ebs primary you don't have a nut so you don't have to worry about it. But for others with the ebs primary and are wondering, the metal nut is shorter and lets the primary shift out futher.
Old Oct 26, 2005 | 04:36 PM
  #17
Thanks Sportsman! I probably would have waisted a day looking for a nut that wasn't even there!
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
