mudlite comments/feedback?
swapped the factory chrome and rubber to ITP wheels and 27 inch mudlites.
immediatley before comming to a stop now, the front of the machine shakes violently for about a 1/2 second.
similar to a penny comming to a hault on a flat surface after "spinning" it.
its very quick, and goes away before you know whats happening.
could this be something in the clutching, or is this the nature of the tire?
thanks!
thanks!
thanks!
thanks!
its the nature of the tire at higher speeds, but i don't have the problem with it stopping, but you have to figure with the larger width, it is going to be much different than the standard narrower tires....i would really look at your steering though to make sure that nothing is loose....I have the '05 700 EFI with 27 Mudlites on Type 5C wheels and I also have a set with 589's mounted...the mudlites wobble more at speeds above 35 mph, neither wobble or shake upon braking
not really under braking, just right before it comes to a hault. braking doesnt affect it.
i was actually impressed that hard turning actually felt easier with these tires than the stockers.
expected it to get worse.
i did notice a wobble at about 40+ on the road. i blasted it through some sand and it felt very smooth.
ill be hitting the mud tomorrow, they will be put to the test.
Does it do it when you ride really slow on pavement? If so, that's the quad shaking as you run over each lug of the tire. It stops at higher speeds because you are going fast enough that the quad doesn't have time to "fall" each time a lug goes by.
Like if you took a coin and cut notches all around the perimeter. If you rolled it slowly, it would bounce up and down. Roll it fast enough, and it would go smoothly as it went over the bumps.
Originally posted by: SPORTSMAN70003
Mine does the same thing when coming to a stop or ridin slow on hard surfaces.
i had contacted ITP about the wobble, they said I could send the tires back to them and they would check them....yeah right, like I'm going to mail all the tires/wheels back to them, just to have them tell me its normal....i think part of the problem is the low pressure, large ***** and that they are not really very round...
I have 27mudlites on my sp700 but now going over 35 is a thing of the past.I was wondering if you could have them balanced like a truck tire,At lower speeds there great and hard biteing over 35 and i look like a bobel head....
yamaguy
Apr 19, 2003 10:32 PM
