Off Set & Bolt Pattern For 2004 Sportsman
'02 sp700
front 12x6 3 3/4 + 2 1/4 ( 4 1/4 + 2 3/4 to outer lip 12x7 )
rear 12x8 5 1/4 + 2 3/4 ( 5 3/4 + 3 1/4 to outer lip 12x9 )
4/156 Bolt pattern
The ITP wheels will offset it outward away from the suspention for use with larger tires at least an inch.
JFYI...
- Vision 160 wheels for Sportsman 700, 4/156 bolt pattern.
12x7 front 4 + 3 offset, 13 lbs
------12" diameter/ 7" width at bead seats.
------7 3/4" outside width total to outer most edges.
------4" offset from mounting face to inner wheel edge. (at suspension)
------3 5/8" offset from mounting face to outer wheel edge.
------2 1/2" offset from outside B.C. face to outer wheel edge.
12x8 rear 4 + 4 offset, 14 lbs
------12" diameter/ 8" width at bead seats.
------8 3/4" outside width total to outer most edges.
------4 3/4" offset from mounting face to outer wheel edge.
------3 5/8" offset from outside B.C. face to outer wheel edge.
Jim
4/156 Bolt pattern
JFYI...
Jim
