Does this mean no recoil starter 500EFI?
Old Apr 10, 2006 | 01:10 AM
Polaris500HO4x4's Avatar
Default Does this mean no recoil starter 500EFI?
Like My 500 has there is something that opens the exhaust valve to loose compression to make it able to turn the engine over by hand
Old Apr 10, 2006 | 01:15 AM
Backinthesaddleagain's Avatar
The Griz does not have a compression release.
Old Apr 10, 2006 | 06:28 AM
gates59's Avatar
The 500 efi will not start without power from the batt. It needs enought power to get the fuel pump going. How often would you really kill the batt enought not to run it.
Old Apr 10, 2006 | 09:10 AM
ricknzep's Avatar
Too bad they didn't use a "batteryless EFI" like my arctic cat sled. You pull it over once to charge the ignition and then release and pull a second time and it starts right up.
Old Apr 10, 2006 | 11:38 AM
  #15
Bill35's Avatar
When your battery is dead in the middle of nowhere you can pull on a recoil alot harder then you think I once pull started a 90hp outboard motor.My dealer said he can get everything needed to but a recoil on my 02 sp700 for $325.
Old Apr 11, 2006 | 12:14 AM
  #16
Ok my Buddy has a brand new grizz 660 that we just changed oil on, "Hookestras Custom Farming" and it pulls easier then you might think... go try one out
Old Apr 11, 2006 | 02:24 AM
  #17
I have three buddies with Grizzlies and none them can be pull started. On another site I asked another Griz owner if he can pull start his.....the answer was no. Maybe I'll post the question over in the Yamaha forum and see what we come up with. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 11, 2006 | 03:37 PM
  #18
awdowden's Avatar
On the newer models, whether carb or EFI, if the battery is COMPLETELY dead, you CAN NOT pull start it. Don't quote me on this but I think this started in '04 maybe. If I remember right the newer design allowed a stronger charging system. The trade off was that if the battery is low, even too low to crank it over, it will still usually pull start; but not if it's completely dead.
Old Apr 11, 2006 | 07:41 PM
  #19
sounds like a plan [img]i/expressions/face-icon-small-smile.gif[/img]
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
