trailboss problems
Old Jun 21, 2006 | 09:12 AM
bangy's Avatar
Default trailboss problems
Hi all,well I have a 92 trail boss 250 that i'm having problems with.I tore the motor down(low compression)the crank seals and bearings were shot.anyway i replaced those new piston ,fresh bore and put back together it started right up but revved real high and shut off now it wont start back up.any ideas are greatly appreciated.thanks
Old Jun 21, 2006 | 05:12 PM
ncriderforks's Avatar
SOUNDS LIKE EITHER THE THROTTLE IS HUNG OR IT'S SUCKING AIR SOMEWHERE
Old Jun 21, 2006 | 10:23 PM
310's Avatar
310
It mabe the oil injector cable is stuck or hung up.
Old Jun 22, 2006 | 09:01 AM
bangy's Avatar
I took the oil injector out and put the block off kit on it.
Old Jun 22, 2006 | 12:15 PM
bjrjr16's Avatar
Is the slide in the carb all the way down? If not then I would assume you have an air leak, Did you replace the crankcase gasket when you did the crank seals? Are the crank seals on correctly and did you instal the spring the holds the seal tight to the crank? There a number of possibilities. Why did you have to bore it? Just to do it or because it blew up? Hope you get it figured out, Brian
Old Jun 22, 2006 | 12:49 PM
bangy's Avatar
yeah new gasket and the seals are on right.Could I have blown a base gasket?oh and had it bored while i had it down.The base gasket was the only gasket I didn't get from the dealer.
Old Jun 22, 2006 | 12:53 PM
bjrjr16's Avatar
It is a new base gasket tho right? Try doing a leak down test if you can. I believe you can find it in a search on what to do. Brian
Old Jun 22, 2006 | 02:36 PM
bangy's Avatar
yeah it is a new gasket i just got it off line. I'll try that. thanks
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
