Pre-Filter Cleaning
Old Jul 12, 2006 | 03:24 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default Pre-Filter Cleaning
Just sending out this post to see what you readers are using to clean the pre-filter. I have been using an auto- car wash soap, and it does not seen to get the black oil deposits off the filter. Have any of you tried spray-nine cleaner????...It says in the manual to use soapy water!!Thanks...... caper..It gets black from the rubber return hose entering the air box.
Old Jul 12, 2006 | 04:03 PM
scrammersam's Avatar
paint thinner when its really bad otherwise costco laundry soap and hot water
Old Jul 12, 2006 | 05:50 PM
Perky's Avatar
dont use PAINT THINNER......use Dawn or Joy dishwashing soap it"ll do the trick...paint thinner will destroy the sock....
Old Jul 12, 2006 | 11:15 PM
NO I will not use paint thinner!!!!I just want to know if spray-nine works good ...or not!!!!
Old Jul 12, 2006 | 11:36 PM
2manytoys's Avatar
Dish washing liquid works very well for filters. It is designed to remove oil on dishes so why not try it. Simple green works good too.
Old Jul 13, 2006 | 01:30 AM
um are we talking about the foam pre filter
Old Jul 13, 2006 | 07:44 AM
liam51's Avatar
The foam pre filter will clean up nicely using dish soap. It will last for a long time as long as nothing harsher than dish soap is used. Use dish soap.......[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 13, 2006 | 03:21 PM
MILKMANZ's Avatar
I Havn't tried it but I don't think spray-nine would harm the stock sock on the 450's. I only cleaned my prefilter a couple of times with dish soap, then the paper filter was full of dust, so I put in a Uni-filter.
You can get the Uni-filter from Royal Distributing for about $35.00 CDN. I think the stock Polaris filter is about $20.00 CDN so the Uni is worth while since it should last as long as the quad does. Foam filters are much nicer to deal with if you swamp the quad...just squeeze the water out. Paper on the other hand...your riding back with no filter on.
Old Jul 14, 2006 | 12:09 AM
I seen those uni-filters in the Royal cag. Do they come with a pre-filter when it is ordered or you need to buy it on it own. This filter is foam I think and needs to be oiled when cleaned.Is that right.
Old Jul 14, 2006 | 10:26 AM
MILKMANZ's Avatar
The uni-filter is a 2 stage foam so the "prefilter" comes with it. The inner foam is more dense than the outer foam. The outer comes off for cleaning and yes it needs to be oiled. I use a K&N filter cleaning kit to clean and oil mine. If the filter is really dirty I use Spray-and-Wash stain remover. There's also a company called Twin Air that makes a two stage foam filter. Don't know how much they are or where to get them though.
Jenn1
Sep 8, 2015 09:16 AM
WilliamBos
Aug 8, 2015 07:26 PM
WilliamBos
Jul 25, 2015 02:41 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
cSchwartz
Jul 9, 2015 02:43 PM
