disabling EBS
Old Aug 3, 2006 | 11:41 PM
xlb3x's Avatar
Default disabling EBS
Anyone know if EBS can be disabled on a 2006 800efi. It is a little extreme. When going downhill I very rarely use brakes the wheels just lock up on their own and slide. I actually have to goose the throttle a little to get the wheels going again. I would rather just use the brakes. I think I would have better control. Any thoughts?
Old Aug 4, 2006 | 01:33 AM
MaineMudder3's Avatar
Primary and secondary clutches have to be changed to non-ebs clutches. Cost ya about $500
Old Aug 4, 2006 | 01:40 AM
plainbroke's Avatar
find someone that has none ebs and trade would be the cheapest wouldnt it..?
Old Aug 4, 2006 | 01:49 AM
Your not going to find an 800 without ebs. Chances are your going to find someone with a 500 without ebs and then you'll have to change weights, springs, helix..etc
Old Aug 4, 2006 | 07:46 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
isnt the ebs just the primary clutch and the bushing to make it work? can that be removed and replaced w/ a standard bushing. just wondering.
Old Aug 4, 2006 | 11:19 AM
The primary clutches are all together different..ebs vs. non-ebs. Mostly the inner sheeves. Also ebs secondary have flat springs and no spun tension. Non-ebs secondary has notched springs that insert 1 end into the helix and 1 into the inner sheeve. The inner sheeve is then turn 1/3 a turn to put tension to the clutch. All together different designs...
Old Aug 5, 2006 | 12:40 AM
ncriderforks's Avatar
Just put a belt on it that doesn't have the grooves cut in it for the ebs. Like a scrammy 500 belt
Old Aug 5, 2006 | 02:54 AM
plainbroke's Avatar
If you lived closer I would swap you. Not sure if 800 and 500 would interchange since they use belts 0f different lengths...
ANGEL2k3
Where to Ride
13
Jan 25, 2004 01:11 PM
VinsonMan03Manual
Sep 28, 2003 04:14 PM
raptorACDC
Jun 17, 2003 10:30 AM
sparkys
Jan 5, 2002 06:30 PM
