02' Sportsman 700 runs 1/2 throttle
Old 09-27-2006 | 08:28 PM
thelimuman's Avatar
Default 02' Sportsman 700 runs 1/2 throttle
Hey Guys,
My 700 hasn't been run much the last couple of years. It runs fine up to 30 mph, then it's like you cut the key off.
You can let off and it will catch up and run fine at about half throttle. I'm guessing a carb cleaning. Any other suggestions or bugs I should look for?
I'm new to the forum, ya'll have a great thing goin'.
Old 09-27-2006 | 10:18 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would start w/ taking the carb off and cleaning it, maybe replace fuel filter. check to make sure the air filter is clean and no debree in the box.
Old 09-27-2006 | 10:49 PM
800stealth's Avatar
running on one bad plug?
Old 09-27-2006 | 11:00 PM
thelimuman's Avatar
Thanks,
I'll pull it this weekend. I've had it off before. The intake manifold (made out of rubber) cracked and nearly
drove me crazy trying to figure that one out. Was a couple of years ago.
Have a great week! And thanks for answering.
Old 09-27-2006 | 11:29 PM
Fireslayer's Avatar
If it has sat for more than a month or so, the fuel has probably gummed up the carburetor. It sounds like the main jet is clogged in the carb. Appparently the pilot jet is still open which allows it to idle and run up to half throttle. If the fuel has been in any length of time I would drain it all out and replace it. Use a good fuel stabilizer,(sea-foam,Stabil etc.) or make sure you all the fuel out or both before storing it for a month or more. Today's gasoline has a very short shelf/storage life. It works well in our autos which rarely ever have the same tank of fuel for more than a couple weeks tops, but not so well in our equipment that only sees occasional or seasonal use. Good luck, sounds like your on the right track.
Old 10-01-2006 | 12:18 AM
thelimuman's Avatar
Thanks for the replies. I pulled the carb bowl, pulled the jet, sprayed everything w/carb cleaner. Put back together
and it ran fine. Didn't see anything though. Anyway, the story ended fine.
The Limu Man
skittero
35
03-01-2019 12:39 AM
armpump450r
Technical and How-To Articles
04-01-2017 06:11 AM
wannabe32
07-07-2015 11:30 AM
gfl0224
06-27-2015 06:52 PM
Big600twin
06-10-2015 03:01 PM
Quick Reply: 02' Sportsman 700 runs 1/2 throttle
