rear yoke on Sportsman
Old Sep 30, 2006 | 09:58 PM
Perky's Avatar
Default rear yoke on Sportsman
I was replacing the roll pin in my 800 and noticed tha you could take a bar and wiggle the rear yoke on the back differential a litlle on the shaft...It doesent have a roll pin or set screw....My other 800 is the same way...Id imagine thats normal because if it couldnt move it have to bind up since it doesent have a slip joint.....any thoughts...
Old Oct 2, 2006 | 01:58 AM
Instigater's Avatar
I responded once, but it didn't make it!
I'll try again. Mine has movement too. I even saw the fron yoke move SLIGHTLY. No slip yoke because diff and trans are mounted to the same chassis part(no suspension travel) The rear is held inplace by the front roll pin. The solid shaft will not move any, if either pin is in.
Is there enough room to get the shaft out, without moving the diff backwards?
Old Oct 2, 2006 | 08:38 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
are you guys having problems w/ your rear yokes braking ??
Old Oct 2, 2006 | 12:00 PM
Instigater's Avatar
No problems here.
Old Oct 2, 2006 | 01:01 PM
Perky's Avatar
No problems here
Old Oct 2, 2006 | 08:57 PM
BigDog800EFI's Avatar
Just the u-joints
Old Oct 2, 2006 | 09:29 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
dog, how are you breaking the u joints on the yokes?
Old Oct 2, 2006 | 10:01 PM
Not sure what you mean? I noticed it was loose so I took it apart and both caps in the front shaft were broke. Really sucked changing it. You have to remove all the bolts from the rear gearcase and slide it back to get the shaft out.
Old Oct 2, 2006 | 10:13 PM
TJ700's Avatar
stripped out my rear shaft on the tranny side.
you have to pull the rear back to get it out.
new shaft and new roll pin and im good.
Sandman2.0
Jul 21, 2015 09:03 AM
Peter_
Jul 18, 2015 07:06 AM
WilliamBos
Jul 13, 2015 02:11 PM
rcappie4
Jul 10, 2015 04:54 PM
Rider252
Jul 6, 2015 03:37 PM
