sportsman 800HP ??????
Old 10-14-2006, 01:58 PM
raidermike67's Avatar
Default sportsman 800HP ??????
I've been of the mind they should beef the Trail Boss to 400cc. Just a thought!
>>>>>>>>>>>>&g t;
I almost got a TrailBoss as my second quad.
Old 10-14-2006, 02:11 PM
Legendary's Avatar
My first bike was an '05 Trailboss. Went everywhere and did everything I needed it to do. But, I always wished it had a bit more top end. Needless to say now I have a Predator and more top end than I'll probably ever get to.
Old 10-14-2006, 02:46 PM
700vtwinman's Avatar
If they made the hawkeye platform with two motor options, they would help. Keep the 300cc and make a 400cc for the halkeye and drop the sportsman 450. From what I understand, there is a big performance difference between the sp450 and the sp500efi, but the cost difference is not that much. Then they would have a 300cc, 400cc basic mid size 4x4 utility along with the 500efi, 700efi & 800efi sportsmans.
Old 10-14-2006, 11:20 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i do beleave that they can just a have a bigger bore/stroke for the more cc's on the 800 engine w/out havinga diffent engine. as far as the 450 being in the line up, it has the same power as the 500 carb in most repects and allows you to kep the carb opition. i think the 400 was a little under powered for the same frame as the 500 and up so they went w/ the 455 cc engine and the 500 efi has close to the 600's power so they did away w/ it. maybe (dont really know) the hawkeye frame isnt strong enough to hold a heavyier and more hp power plant. as far as the yam. 450 goes there a good bike i ride w/ 2 of them a 400 kodiak. but they dont hold a candle to my wifes sp 450 in any repect except fuel milage. not sure about the the new yam 450 but older ones and the new 400's there is no override on the reverse's which sucks when you try to back up when your stuck and it cuts out.
  #15
Old 10-14-2006, 11:31 PM
True but I always kinda thought HO engines utelized more valves? The Outlanders are all advertised as HO and have either 4 or eight valves.
  #16
Old 10-15-2006, 03:20 AM
TTP's Avatar
TTP
TTP is offline
Sounds just like thier Limited Edition models.
Although, they offer special colors and decals only.
Adding JUICE to the motor would be a welcoming addition.
Good stuff!!!!
  #17
Old 10-15-2006, 09:31 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
just a bigger cam would boost hp a litltle so the cc's and a bigger cam would be sweet. i think thats what they did on the sportsman 500 to go to the 500 ho which i think was like 8 more hp but there again im not to sure i beleave they did it back in 99' area.
  #18
Old 10-15-2006, 10:15 AM
spyder6's Avatar
they still need to lighten the SP's up. polaris needs to invest in Forged Aluminum tech.
  #19
Old 10-15-2006, 12:33 PM
pout's Avatar
Someone said that the 800 have 54hp, i've heard about 50...
So if the 800 have 54, how hp have my 2006 700 EFI...
Thanks
Pout
  #20
Old 10-15-2006, 12:54 PM
powerslider's Avatar
I wasn't implying they just throw a bigger engine in the same frame on the Hawkeye, my thought was a beefed up version all the way around.
The 450 Kodiak has many more features than the 400, mine is an 06 and it doesn't lack anything in features other than storage IMO. They went to IRS in 05 otherwise I wouldn't have bought one. Biggest gripe about it is the positive camber issue in the front, I don't like that set up. Should be slightly on the negative side instead and they don't have much for tires but I switched them out already....
chingchangchong
08-07-2022 11:36 AM
Jmuddin284
06-28-2017 04:59 PM
slowgsxr97
09-08-2015 07:33 PM
Pahuntman
09-05-2015 11:07 AM
cdstang
08-31-2015 07:52 AM
Quick Reply: sportsman 800HP ??????
