clutch kit
Old Mar 5, 2007 | 07:02 PM
eddy1's Avatar
Default clutch kit
ok guys i know this has prob been talked about a lot but....i have a basically stock 1999 scrambler 400 accept with a fmf pipe...my acceleration on WOT seems like it slips and lags my chain is tensioned right but i was wondering if it could possibly be a belt issue or clutch...would yall suggest buying a clutch kit? and if i do so do i need a new belt or anything else....also i am thinking about the RCR performance stage 1 would i need anything else to go with this...by the way im not to mechanically inclined any help would be wonderful..thanks again
Old Mar 5, 2007 | 08:14 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default clutch kit
most likey the clutches could be cleaned and sounds like it could use a new belt.
Old Mar 5, 2007 | 08:38 PM
onesavage's Avatar
Default clutch kit
stendori is correct , sound like a clutch issue or a belt.. give the primary clutch and weights a good cleaning and replace the belt and go from there... stendori is VERY good at this kind of thing..
Old Mar 5, 2007 | 09:17 PM
ftwflh's Avatar
Default clutch kit
When you add a pipe to a 2stroke polaris you need to reclutch to the rpm of the pipe.
Either get the RcR Stage one kit with pipe and everything and ditch the FMF or try a brown primary spring and a HPD violet secondary with the FMF with stock weights.This may help but wont be on the money
Old Mar 5, 2007 | 09:27 PM
onesavage's Avatar
Default clutch kit
stupid question what is hpd... or who ...
Old Mar 5, 2007 | 11:08 PM
ftwflh's Avatar
Default clutch kit
High Performance Design they are one of the top Polaris builders and aftermarket performnce part suppliers
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
