charging problem 99 Sportsman 500
Just looking for a little confirmation with my troubleshooting. I have the repair manual and been through the flow chart. Basically with it running I have about 12V at the battery. Not good. I also have 12V on the red wire at the rectifier. This is good. The next test is to unplug the yellow and yellow/red wires from the stator. Then take a multimeter and put the red lead in the 10 amp jack, switch the meter to A~, start it up and test the amps on the yellow and yellow/red wires. I guess this replicates a full load on the stator and the output should be 5amp or higher. I get nothing. Basically I put the red probe from the meter on yellow and black on the yellow/red. I got 0 amps. Then I switched the probes and still got 0 amps.
I assume I did this test right? If I did the manual says there is a problem with the stator. Can someone confirm what I have done so far?
Thanks, Jon
Thanks, Jon
If your checking for amperage.....You need to be in-line...or other words.......both probes in one path for the current to flow for a amp reading......Other way is to have a clamp-on meter, which will need to be AC/DC for the reading to work on your 12 volt system!!!...Caper.........
Thanks for all the replies. I started testing the stator output with a fancy electronic Fluke tester. I never thought to check the fuse on the 10 amp plug but maybe I should have. I decided to check the output with a cheap Radio Shack meter and what do know, I had about a 5 amp output on the yellow and yellow/red wires. I guess I need to look at the fuse in the Fluke.
Looks like it's time to find a voltage regulator.
Thanks again.
Thanks again.
skittero
35
03-01-2019 12:39 AM
