MAGNUM325 4X4 OIL PROBLEM
I AM LOOKING FOR ANYONE WHO HAS HAD A PROBLEM WITH OIL COMING OUT OF THE AIR INTAKE SNORKLE ON A POLARIS ATV MINE IS A 2001 AND HAS LESS THAN 10 HOURS OF SERVICE WHEN IT FELT SLUGGISH AND THEN FOUND OIL DRIPPING FROM THE AIR INTAKE SNORKLE .
WAITING FOR DEALER TO OPEN TO FIND OUT WHAT THEY SAY BUT ANY HELP WOULD BE APPRECIATED
moor325
I assume when you talk about the air intake snorkel, you are talking about the air intake for the carb and not the pvt. The engine oil system is vented into the air box. The only time I have had oil in the airbox on my 325 is because I flipped it backward
and the oil was allowed to run in. When the oil ran in, it soaked my air filter, causing it to run crappy until I replaced it. I assume you have checked the oil level in the engine and it is not overfull. If the engine oil level was to high, it will spit oil out through the vent line. Also, you may have some sort of oil line restriction that is causing extra pressure in the system, causing it to spit oil out through the vent line. Check all of your oil line to see if there is any that are pinched. Hope this helps. Be sure to clean all of that oil out of your airbox or you will have a dirty mess when the dust eventually begins to fly.
