error wrench flashing on speedo
Old Jul 20, 2007 | 11:28 PM
SnakeBite's Avatar
Default error wrench flashing on speedo
I have an 04.5 Sportsman 700. The wrench has been flashing on the speedo for a while now. I think the hours on the machine are about 65. It only flashes when first started and shortly after taking off it goes out. Any ideas?
Old Jul 20, 2007 | 11:31 PM
SCRAMMYTODD's Avatar
Is it the service indicater?? Usually the factory setting for the light is 50 hours and then you're supposed to service the bike and reset the light. Hopefully you just serviced your bike and forgot to reset your light.
Old Jul 20, 2007 | 11:33 PM
SnakeBite's Avatar
how do you reset the light?
Old Jul 20, 2007 | 11:40 PM
You have to get into Diag mode. And if I remember right, with the bike in nuetral and the key off, hold the brake on and the override button, then turn the key on. It wil say V2.5 or whatever your version is. Press the override button to cycle thru the options and when you get to the wrench, hold the override button to set the hours. Double check your owners manual, but I think that's the correct procedure
Old Jul 20, 2007 | 11:42 PM
SnakeBite's Avatar
thanks
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you have your book, just look in there under service or instrument and it should tell you. most people reset them to 50 hrs and it counts backwards to zero and triggers the wrench to flash.
Old Jul 20, 2007 | 11:56 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
post
here is another post telling you how to do it if you need more info.
Old Jul 21, 2007 | 01:17 AM
SnakeBite's Avatar
For the life of me, I can't find my manual. I printed this and the link topic posts and will try it in the morning. Thanks again!
Old Jul 21, 2007 | 06:08 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
manual
here you go. go to page 50 and your there.
Old Jul 21, 2007 | 05:30 PM
SnakeBite's Avatar
All fixxed! That was it. When I checked, it was at 0.0 so I reset to 50 hours. Thanks
speedbuff
13
Nov 11, 2020 10:16 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
exmotocrosser
Sep 26, 2015 08:18 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
