05 500 HO FRONT DRIVE SHAFT
Old Aug 29, 2007 | 10:50 AM
KINGSCLEAR's Avatar
Default 05 500 HO FRONT DRIVE SHAFT
I had a guy grab the front shaft on my bike and he moved it back and forth, he told me the drive shaft was bad. I know it always has been slack but it hasn't seemed to bother it any. No noise or problems . Now is this guy right or is he as usually just picking my Polaris a part? I keep it greased .
Old Aug 29, 2007 | 07:18 PM
duffus's Avatar
Is this the drive shaft that connects the transmission to the front axle? Or the front axle to the wheel?
if he can move the axle/cv joint axle that connects the front differential to the front wheel, it is probably okay-- they are designed to "slip" some.
Old Aug 29, 2007 | 09:28 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
they all have a little slack. there not suppose to be 100% tight i dont beleave.
Old Aug 30, 2007 | 07:52 AM
KINGSCLEAR's Avatar
This is the drive shaft that goes from the tranny to the front differential
Old Aug 30, 2007 | 09:08 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is the joints nice and tight. is the shaft on the spines sliding back in forth. waht part is suppose to be bad?
Old Aug 30, 2007 | 09:13 AM
KINGSCLEAR's Avatar
It appears to be sliding back and forth on the splines
Old Aug 30, 2007 | 09:20 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
does your have roll pins in the ends to prevent it from moving back in forth. if so are they missing or sheared off?
Old Aug 30, 2007 | 09:25 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the parts manual shows one spring pin on the short end of the yoke shaft and i think a grease fitting on the other end.
KINGSCLEAR's Avatar
I'm going to jack it up tonight and pull the front wheel so I can get a better look, I blew it off the other night because this guy gets great joy out of picking apart the Polaris line, he is a Honda nut and everything else is inferior to him. I'll see exactly what it is doing and where this movement is I'll post tomorrow what I find. Thanks for responding I appreciate any imput I can get
KimSJoh
14
Jul 18, 2015 07:20 PM
JackTheKing
Jul 14, 2015 09:09 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
