Any new news on the HPD reed conversion for the TBlazer?
Old Apr 18, 2001 | 11:05 PM
  #41
x_scrambler3's Avatar
I have the raceporting an head work done from HPD an retarded the timing. The motor is strong has good pull the motor only gains 250rpm's from the mods. So red line is 6750rpm's for the motor. Im running 100 oct gas that is what Daryle at HPD told me to run in it. Im thinking with the mods I have plus the weight an putting 20" tires on the rear I have 18" now I think I could hit 60mph. When I first had it an did some small changs I had it up to 50 to 55 on tar. This is going off the speedo from a 96 400 explorer. If someone has a 34mm carb an pipe an have about $260 plus the money to have it bored plus a new piston it is well worth it. All together it is $410 for the bore an piston an machining.
Old Apr 19, 2001 | 08:55 AM
  #42
00TB250's Avatar
Thats $410 for boring, porting, wiseco and headwork?
Old Apr 20, 2001 | 12:08 AM
  #43
The porting is $200 head work is $60 the Piston is $98 an the boreing was $50 from my Polaris dealer. An you need the 34mm carb.
QuadRiders
Oct 22, 2015 04:13 PM
Halffast17
Sep 11, 2015 02:30 PM
Jaymc
Sep 11, 2015 07:45 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
Jason Richards
Sep 4, 2015 06:17 PM
