hillard clutchs
Old Jun 26, 2008 | 08:42 PM
atvrider007's Avatar
Default hillard clutchs
how far are the tabs supose to come out when disengaged then how when engaged cuz it just forces them in inorder to got the wheel hub over the clutch then there stuck
Old Jun 26, 2008 | 11:52 PM
Say what? Just kidding! When awd switch pressed strut coil holds armature plate which allows hilliard to float in hub and engages when back tires slip 1/8 turn. simple system,only problems are plates than permantely stick to coil (magnetized) allowing one wheel to engage even in two wheel drive. Replace plates when this happens and change hub fluid every 50 hrs,check for leaks(strut or hub seals) Very little movement on plate when engaged and disengaged. Hope this is what you asked for?
Old Jun 26, 2008 | 11:59 PM
i have to new plates but the tabs that apply to the hub arent engaging i went to he dealler to tell what to do and they told me to file the inside of the cage where the tabs are so they can move but they still dont and idk whats the proper way to put it back together
Old Jun 27, 2008 | 11:35 PM
First if you have hub still off, put in gear,turn awd on,see if plate holds tight to coil. Check that the inside spacer of the hilliard turns smoothly and hilliard spring and roller bearings and cage cam up and down on spindle(driveshaft). Dont drill bigger slots in cage. Look for assy diagram if not sure how to go back,final torque 12ft pounds on driveshaft nut. Tabs should line up on hilliard,if not cage worn or damaged.
Old Jun 28, 2008 | 12:41 PM
MECHANIKE's Avatar
the main thing is 0 play..................
Old Jun 28, 2008 | 08:33 PM
i can get tabs in into cage just dont move as freely as there supose to so i think the cage is bent in slightly on the outside im goning to try to file it to see if it will work otherwise ill need a new cage
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
