Can Someone Help Me Get My Polaris Running!!!!!!!
When throttle is first applied the motor sounds as it should,snappy and responsive,but once it gets about halfway that goes away and it sounds like a struggling boat motor in the water.What will cutting the black wire to the rev limiter tell me/or do?
#15
#16
Hello,When I replaced the rings I found out the piston had been replaced and was a larger size.I dont know if they got a larger piston to compensate for a worn out jug or if someone actualy got it bored,which I doubt because the etching is long gone and there were some vertical scratches.My friend is coming over with a compression gauge,Do you happen to know what the compression should be? I will take the head off and mic it to see what the gap is as you suggested.Ill post what I find out.Hopefully after deminishing everything it isnt,Ill find out what it is !! Thanks for the gap specs !!!!
whitty
67
02-24-2021 02:52 PM
skittero
35
03-01-2019 12:39 AM
hoopduerr
06-02-2015 09:01 AM
