Replaced front shaft now i have no speedo
I have a 99 sportsman 500 last week i replaced a front shaft and now my speedo dosn't work the display for the hrs work thats it, is there a easy cheap fix for this, also i'm replacing a rear shaft what is the tork spec's in ft lb for the outer shaft nut, thank you for any help on this
I'll take a wild guess and say there is either a speed sensor or wiring that you damaged/disturbed or a connector that is disconnected if it started right after you worked on it.
jayking232003
Dec 4, 2019 09:38 AM
Rooky
10
Jun 23, 2015 09:35 PM
