2005 sportsman 600 shifting hard
Old Oct 12, 2008 | 10:15 PM
hurly's Avatar
Default 2005 sportsman 600 shifting hard
Im having trouble shifting when the atv is running. as soon as i turn the machine off it will shift with no problem. Any ideas????
Old Oct 12, 2008 | 10:22 PM
Is machine creeping in gear? could be source of hard shifting,either way sounds like clutch is causing problem if can shift ok with engine off!
Old Oct 12, 2008 | 10:28 PM
hurly's Avatar
that sucks!!! it is creeping....im not to expierienced with atv clutchs but have changed a few on cars and trucks...is it hard to change the clutch? i no its pricey at a dealer.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Oct 12, 2008 | 10:44 PM
NOT necessary to change clutch! Usually one way bearing on front clutch needs cleaning/lubrication or clutch alignment problem..remove cover blow out dust(well ventilated area a must) check belt to see if worn/glazed,also one way bearing in front drive clutch must be free to turn smoothly one way only and must have .020 clearance between back of one way bearing and clutch sheath. MUST have special tools to tear down front clutch if its the problem. Rear driven clutch has roller bushings that can wear also. CHECK the easy stuff first! Belt usually rides up on sheath not allowing bearing to do its job! While running rear clutch should not turn! Shims can be added/removed from behind rear clutch to help align also,plus front motor mount can be loosened and pulled rearward if necessary to see if helps! center to center of clutches should be 10 inches(measured from center of clutch bolts) Dont know if this helps you,but can possibly give you a way to check out! Good luck keep us posted
Old Oct 12, 2008 | 11:18 PM
hurly's Avatar
i appreciate the help....i will look into it on my next day off. ill keep you posted...thanx again!!!
Old Oct 12, 2008 | 11:24 PM
biz4two's Avatar
Thought this video might help some...and give you an idea of what's going on.
Changing Polaris ATV belt
Good luck...
biz
[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 13, 2008 | 01:28 AM
Jocko's Avatar
Good link biz. Thx for posting!
Old Oct 13, 2008 | 01:46 AM
hurly's Avatar
awesome link....i think ill become a polaris tech...lol...i just learned more off the link then i would ever learn out of the manual.
Old Oct 21, 2008 | 05:53 PM
krausemouse's Avatar
I am having the same problem and a buddy told me about a possible bearing issue. However, and I'm sure this isn't the best mechanical advice, I found one solution is to simply turn your idle down. My idle was pretty fast (about 1400 I think). When I turn it down so that it reads around 1000, it shifts fine.
Old Oct 23, 2008 | 08:48 PM
hurly's Avatar
thanks...i did turn the idle down and it does help..
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Shifts
14
Jul 13, 2015 08:41 AM
tporath
Jul 11, 2015 12:31 PM
Shifts
Jul 3, 2015 07:59 AM
