Engine dies when I shift into reverse ??
Old Oct 26, 2008 | 03:03 PM
Borin's Avatar
Default Engine dies when I shift into reverse ??
The engine dies when I shift into reverse. It just started doing this. The only thing I have done recently is replace the ignition switch.
Its a 94 Sportsman 400 4X4.
Any Ideas ?
Thanks
Old Oct 26, 2008 | 03:12 PM
ardakota's Avatar
it sounds like its in the limiter can you hold the override switch in and put it in reverse and it stay running mine was like that and i did away with the limiter and fixed the problem.
Old Oct 26, 2008 | 03:28 PM
Borin's Avatar
YES! it works when I hold in the override.
How do you bypass the limiter ?
Does bypassing it have any ill effects ?
Old Oct 26, 2008 | 04:13 PM
Disconnecting limiter allows full power in reverse,override button is disabled. Older machines prone to have this happen. just disconnect black wire from limiter module that goes into terminal board.
Old Oct 26, 2008 | 04:42 PM
ardakota's Avatar
i couldnt see anything wrong with it only thing i found out is i didnt have to worry about that stupid switch any more.
Old Oct 26, 2008 | 07:15 PM
ftwflh's Avatar
By pulling the black wire you will still need to hold the button to have 4x4 in reverse
Old Oct 26, 2008 | 07:23 PM
Borin's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ftwflh
By pulling the black wire you will still need to hold the button to have 4x4 in reverse</end quote></div>
Thanks for pointing this out [img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 26, 2008 | 07:28 PM
HARLEY_OWNER's Avatar
yea like he said pulling the black wire... i literally just did this the other day... after you take you headlight assembly off there is the wire board or whatever.. on the top left there are 2 black wires one on top of the other.. you take out the bottom one... when i first did it i took off the top one.. i was like YES i fixed it.. pulled it back in the garage and shawzam the wheeler wouldnt shut off... so yea make sure you do the one below the first one...
KimSJoh
14
Jul 18, 2015 07:20 PM
sara durrant
Jul 6, 2015 05:32 PM
ranvette
Jul 4, 2015 06:13 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
