HD springs (Front)
Old 01-12-2009, 06:18 PM
mtpockets's Avatar
Default HD springs (Front)
I just installed one set of rubber spacers.....it fit my budget.
Made a slight difference.
Is the new XP front shocks adjustable? Anyone know?
  #52
Old 01-12-2009, 06:20 PM
JCDEYO25's Avatar
I'm not sure about the shocks but the springs have preloads on them now....
John
John
  #53
Old 01-12-2009, 07:14 PM
brutus450's Avatar
  #54
Old 01-12-2009, 09:13 PM
RticKwad's Avatar
Runs Stealth!
Thx RolliePO-
Yea let us know!
Cheers,
R'
  #55
Old 01-15-2009, 01:07 AM
RticKwad's Avatar
Runs Stealth!
RolliePollie and/or 5J's -
Did you get your springs yet? Well I got them today, whippee! But when I unboxed them and looked
at the instructions it says 2005-2007, but I matched the Part numbers to this thread all looks good. When
I look at the instructions it has the steering post removal, strut replacement and and steering rod.
I thought all I need to do is remove the cargo box and the top strut bolts? Please advise!
R'
  #56
Old 01-15-2009, 08:23 AM
Rtick, if you are just replacing the springs you don't have to do all the instructions tell you to do. Those instructions cover the actual removal and replacement of the struts if I remember correctly. All I did when I did mine was to take off the front box (not a problem), jack up the front end so the tires are barely touching the ground, and take the top nut off the assembly so the spring can be removed. I had to put a small socket on the end of the shock piston rod so I could turn the nut that holds the assembly in place. The only thing to be careful of is lifting the front end so far that the tire is hanging in midair for a long time. Hope this helps.
  #57
Old 01-15-2009, 08:58 AM
RolliePollieOllie's Avatar
Haven't got them yet. Shipping to Canada probably slows the process down a little.
  #58
Old 01-15-2009, 10:54 AM
*5 J's*'s Avatar
I picked mine up but haven't installed. I don't have a garage and it's been below zero outside.
I saw the steering post removal in the insturcions also, but I am going to do as suggested in this post and summarized my moose just above.
  #59
Old 01-15-2009, 11:07 AM
JCDEYO25's Avatar
Yea Moose has got ya covered....When I did mine after I jacked the front end up just to get the tires just off the ground I think I had to slightly jack the machine up slightly to get the strut out of the bracket...Very easy to do and no compressors needed to do the fronts....Once the box is out of your way, you have plenty of room....If I remember correctly you'll need a 3/8" socket to hold the top of the strut from turning then a 3/4" open end wrench to remove the large nut....Piece of cake guys......Just remember, leave the tires on and don't jack it up too far.....
John
  #60
Old 01-15-2009, 10:07 PM
RticKwad's Avatar
Runs Stealth!
Good info. I will post my results and some pics I hope. Same
here man, 7 degrees tomorrow. So its going to sit for a few until
another above 30degrees day.
Cheers,
R'
Quick Reply: HD springs (Front)
