oil level on my 07 800
On my 800 i have noticed that when i change the oil and filter i put in the required 2 quarts and of course run it and let it sit and then check the oil level it is not full it is in the middle of the safe zone is this what others have found? And yes it is on a level surface.
oil level
I put the 2 qt's they say to put in and it is in the safe zone. I check it each time I take it out and it has never got lower on the stick. Question! do you let it set for a littel befor you check it? If not some of the oil will be in the top end of the eng. You need to let it drain down then give it a check. JMO
I do leave it sit for a while before checking. I do run a after market filter. Maybe thats what is making the difference. I was just wondering what others have found. Thanks to all that replied. I just like to keep it at the top of the safe zone. I have to add about 4 oz more than the 2quarts that is recommended.
1ArmBandit
55
10-14-2015 09:03 PM
Elkaholic
09-06-2015 02:44 PM
